Wires 2B and 2C on M1151
Autonomy_Lost
1,554
Pennsylvania
I've searched the TM for 2B and 2C but got zero results. I also searched this website and google, but found nothing.
I have 2 wires dangling under the hood, labeled 2B and 2C. One is male and one is female (I think?). They are part of the same wiring harness with no other wires, and they run through the firewall into the cab somewhere.
Does anyone know what these are for and where to hook them up?
Not sure if its related but my tachometer and temperature gauges are not functioning.
Hummer Guy
823
United States Louisiana
Someone correct me if I'm wrong, but I think those go to the generator. I can check today if no one gets here
Autonomy_Lost
1,554
Pennsylvania
There is 2A that goes to the generator. But I dont have any open terminals on the generator at this point, and I dont have any charging issues that I know of.
Hummer Guy
823
Autonomy_Lost
1,554
Pennsylvania
Mogman
10,475
Papalote, TX
TM 9-2320-280-20-3 somewhere around page 1160. not sure if that is the TM for your vehicle but the number schemes are the same for all MVs with the exception of a few specialty accessories
Wire #2 is the alternator AC tap, used by the EESS and tachometer
The A,B,C,D etc are different branches or segments of the same circuit
Mogman
10,475
Papalote, TX
If they are male/female plug them together and see if the tach starts to work
Autonomy_Lost
1,554
Pennsylvania
Wait a minute, here is the copy of that TM I'm looking at, which only goes up to page 953:
And you're saying that A B and C can all just be spliced together?
Mogman
10,475
Papalote, TX
What I am saying is that the wire number is the circuit, in this example it is "AC tap" now on most earlier vehicles there is only a 2A, it goes from the AC tap terminal on the alternator to the EESS box and that is it'
On later versions that use the AC tap to feed the tach there could be a 2B, 2C, 2D, etc the A B C etc is ether different segments for example 97A and 97B go to the RPM sensor, different segments of the RPM circuit OR it could be branch circuits where the same circuit goes to multiple locations.
So some investigation needs to be done because nothing is absolute just like wire #2 being used in the arctic heater kit.
Pictures of the exact location would help
But because you have a tach and it is not working, if it is the type that uses the alt signal than that signal should be a #2 circuit, I have not been able to find the documentation on the tachs hopefully someone will step in here and help
Autonomy_Lost
1,554
Pennsylvania
I double checked, and 2C is actually a ring lug. 2B is a packard conector (male housing, female pin).
Conveniently, 2C will plug into 2A, and the ring lug can go on the AC output of the alternator regulator. I'm gonna try that and see what happens.
