I have a question. My ‘96 1078’s ctis seems to operate ok except the hwy switch doesn’t activate and light up. It do when I bought the truck 3weeks ago. Now it doesn’t. No threads talk about this situation. Any ideas
First guess would be a bad controller.
The valves, etc are all used in the various modes. If only one mode is out and the others function, I'd say the controller is fubar.
You have options:
1) Replace with used (keep in mind these things all fail at a certain point like the one you have and even used are not typically cheap)
2) Replace with NOS (expensive and I mean REALLY expensive and at some point, they all fail)
3) Replace with manual (several members here have done this, no computer to fail, it's inexpensive, and not difficult to convert)
4) Replace with another controller type (several users are running Arduino controllers, a tiny project computer assembled and programmed for the same task as the OEM)
You can find all of these solutions here on SS. No shortage of used or new. The manual setups are well documented in a couple threads here. And Christian here sells Arduinos that are plug-m-play.
Also keep in mind there are a couple versions so be certain what you buy will work with your A0 truck.
