- 313
- 598
- 93
- switzerland
I read somewhere that the "E" code was used when the truck was ear-marked for sale. It's why it appears to be added after the rest of the stencil. Whoever applied my "E" did so sloppily, you can see that there was "A" before they covered it up. Not sure what that's worth, but figured I'd share.CARC is when it was painted
CC:E was last “condition code” assigned to truck
Serviceable material which requires test, alteration, modification, conversion or disassembly. This does not include items which must be inspected or tested immediately prior to issue. E. Unserviceable limited restoration.
I'm a little surprised by that.As noted above, C/C is Condition Code - E indicates that the equipment is only to be repaired if the expense is limited (as in no major repairs will be carried out, so if the engine goes out, its off to disposal).
A means like new; B means serviceable but with some restrictions on issue to certain units; F means the item is obsolete, anything breaks and its gone.
There are others, but they are rarely seen on MVs.
It is, on the side of the truck is a plate with the rbuild informations. IROAN and made in BarstowREB. is rebuild date, yours doesn't have one.
There is usually a REC., with the date the item was received by the current unit.
Will this mean this car was outside the us aber the rebuild?PRES. is preservation code, what level of preservation an item has had applied while on a ship. In this case none but maybe intake/exhaust covers, it is ready to drive.
As is so often the case in the military. Things are done because they were ordered that way. There is no question about the meaning and later use.P000 is the location code aboard the ship. According to my son "Only Squids know what that means..."![]()
I have not noticed that before. I'll have a look the days.Does your vehicle have a UIC? It will be an M followed by five numbers, example M21640. Usually painted somewhere along the sides, and sometimes on the back.
