This is good to know, I was not aware. What is the best method to wash this? Degreaser in water in a five gallon bucket? Thanks.One thing you need to consider. The military filter can be washed and reused again and again. Commercial filters cannot.
This is exactly why I went with an m35a3 intake and filter on my m109 when I put an LDS in it. Stock m35 filter is 410cfm, m35a3 filter per the phone call with the manufacturer is 575cfm.This is just a thought but knowing how these engines do not like intake restrictions (poor flowing aftermarket filters). I wonder if turned up trucks would benefit from a different filter setup that can flow more air and possibly decrease egt’s. We know that the dust bowl filters cause higher egt’s so can the reverse happen with more capacity.
I added a Donaldson Air Ram snorkel to mine to achieve a bit of positive head pressure to the air filter canister when the truck is in motion.Does cutting a second intake hole in the can help any with temps?
That is because the turbo on the deuce it terribly inefficient and any intake restriction causes a increase in intake air temps and a rich condition in the combustion chamber.The replacement one I got is the smaller dia and my temps go up quicker with it. Very frustrating.
I had looked for that conical filter but it is NLA unless you can find it. Something out there has to flow better with good filtration.
I've been looking for the fender mounted filter but haven't found one close by.
My 6.7 cummins has itty bitty filter compared to whats on the Deuce and it pushes 400 hp.
Trying to find the five ton air cleaners aren't easy either, and the few I did find, the shipping quotes were insane. The thought of buying a big rig filter housing like one from an international or mack seemed like a good idea, fabricating a bracket so it fits and bolts to the fender and then use a reducer to fit the air intake pipe. Looking online has been a bust, I need to find a semi junk yard or an old semi grave yard to look and pick from in that case. In some cases, maybe even a filter box off a tractor or industrial equipment, but all that seems expensive if found online.Yeah I had seen that and tried to find one but have failed so fair.
