MEP-802A Fuel filter replacement advice
webboc
34
13
Lincolnshire, UK
I would be grateful if anyone could give me some advice or tips on how to prime/purge the fuel system on my MEP-802A as I will be shortly replacing the two fuel filters on it. Many thanks.
Guyfang
26,265
Burgkunstadt, Germany
I will warn you now, the filter is a real bear to change. There are about a million threads that explain how much of a PITA it is to get off. Also, the water separator has a small filter in it. Both should be changed. When you read the TM and then get started, take your time. Don't get frustrated. When you do get the filter off, and get ready to put the new one on, take the time to pour some clean diesel in the filter, before replacing it. Its not required, but helps purge the air from the system faster.
webboc
34
13
Lincolnshire, UK
Many thanks for the advice and I appreciate the tip about filling the new filter with fresh fuel before installing.
Daybreak
2 Star Admiral
1,522
773
Va
Have fully charged batteries. After changing both filters, cup cartridge filter, and the spin-on water fuel filter, you will turn S-1 to "Prime & Run" for a long time. It could be 5 minutes. Any excess fuel returns back to the tank thru the fuel return lines. The fuel return lines might need replacing too. If the fuel return lines weep, you will need to replace them.
Start this thread here, 2nd post has quick links of interest, 3rd post has links to manuals.
MEP-802A MEP-803A Filters and Parts | SteelSoldiers
