PART NUMBER/NAME FOR STARTER SOLENOID MOUNTED ON FRAME
Ronmar
8,316
Port angeles wa
Yep, little guys are the coil and big guys are the contacts. If you follow the wires from the big contacts, one goes from where battery + connects to the solenoid and the other connects to the starter solenoid coil in. The aux start relay completes a circuit between these two points (applies 24V to start solenoid) when it is energized. #4 and #7 on this diagram.
BERZERKER888
895
Daytona, FL
thanks Ron !
Guyfang
27,124
Burgkunstadt, Germany
Correct. It will not get simpler than this relay.
One big lead from 24VDC+ source.
One big lead to the load.
Makes no difference how they get hooked up.
One small lead from 24VDC+ Source.
One small lead to ground.
Its easy!
