- 2,904
- 7,062
- West greenwich/RI
Evvy, is the front of the generator housing totally solid or does it have air openings in it?
If I recall from your original post, you bought this set from a private owner, not the govt. auction?
Normally when I get a new machine, first thing I do is steam clean everything to get off all the dirt dust and oil / fuel junk.
I'm wondering if the previous owner washed it and then let it sit with a little water in the bellhousing??
It doesn't look like anything I would be concerned about as it appears to be water, not coolant, and it has since dried up.
I assume your radiator is still holding full?
