The Noco GEN5x2 is what I have been running without issue.I use the generation of this product before this (GENM2... discontinued now I think). Its worked well for years.
NOCO - 2-Bank 10A On-Board Battery Charger - GEN5X2
The GEN5X2 is a 2-bank 10-amp waterproof on-board battery charger for lead-acid and lithium batteries and rated at IP68.no.co
Which one did you use from Amazon? What did it do?Hmm, was looking for a 24v, I guess I wasn't going down the correct path. I will get one ordered.
Thanks!
I had ordered one of these, but I waited too long to return it as I left it for a couple of months before hooking it up.Which one did you use from Amazon? What did it do?
This may be one of those questions.... Do you simply hook up the positive / negative to each battery while leaving the batteries hooked up in 24v series? OR do you need to disconnect one of the batteries while using the 2x12v charger?Yes, a 2x 12V output maintainer unit capability is best when dealing with two 12V batteries hooked in series. Each battery is an independent unit & for best results should be charged & desulphated based on each battery's chemistry & state of charge.
Otherwise, using a 24V output charger is just an average reading of the two batteries in series. I too switched from using (2) 12V Battery Minders, which worked well, to now using the single unit NOCO GEN5x2. They are built very solid & work great along with having one less cord to deal with than the 2X Battery Minders!
As Kurt said... no issue hooking up as they sit in the machine. Just don't energize the charger while the machine (ie the battery charging alternator) is running. You can get into an overcharging situation.This may be one of those questions.... Do you simply hook up the positive / negative to each battery while leaving the batteries hooked up in 24v series? OR do you need to disconnect one of the batteries while using the 2x12v charger?
I just bought my second of those chargers. the first one i put a Nato plug on and use it to charge all of my Generators and LMTV. no problems at all with it. have not tried the second one yet.I had ordered one of these, but I waited too long to return it as I left it for a couple of months before hooking it up.
It detects my batteries as 12v and then complains about being overvoltage.
I worked with the vendor, and they sent me the 2nd one (the 1st was red, and the replacement is yellow). I had the same issues with the 2nd one.
The power pole connector I installed to the batteries last read 25.3v when I was testing it out.
The 1st one was another cheap China one, and it was sent back as it never powered on.
Are you saying that the battery maintainer needs to turned off or unplugged running the generator?As Kurt said... no issue hooking up as they sit in the machine. Just don't energize the charger while the machine (ie the battery charging alternator) is running. You can get into an overcharging situation.
I have the noco genius 24 volt maintainer and it works great.What is the current recommendation for a 24-volt battery maintainer? I haven't had any luck with two cheap Amazon ones so far.
Thanks in advance!
I have the noco genius 24 volt maintainer and it works great. When I bought the truck it already had these batteries in it. I'm going to reconfigure the whole battery tray soon similar to what Sean filner did. The big alligator clips are just for something temporary. The noco's leads are screwed onto the battery clamps with ring terminals.
