- 10
- 19
- 3
- Richmond, Virginia
I have a 200 gallon tank with 2" NPT fittings on the top that I want to use with the aux fuel pump built into an MEP-1040. I've seen some of the original jerry can adapters that use threaded copper tubing as pickup tubes. I understand the fitting on the machine is a bit of an odd-ball -5AN so was planning to use -06 3/8" hose from the tank to the generator with an adapter but haven't found any fittings or adapters on the tank side yet. Before re-inventing the wheel was hoping some folks here might have some answers to help me out.
Any ideas / suggestions? Thanks!
