- 181
- 106
- 43
- Wisconsin and Illinois
I have a military cutoff switch kit and it's instructions.
It essentially cuts off the positive feed to the busbar from the front battery and the feed to (from) the voltage regulator and 12V circuit (TCM/circuit breaker) using a 4 pole/2 switch box.
My concern is cutting off the positive feed only can still short the battery when working on the battery, ie wrench contact from positive battery lug to battery box.
My thought was to use the part of the cutoff to disconnect the main negative feed to the shunt/main ground. And use the other part similar to the military spec, ie cutoff the voltage regulator and the 12V feed.
This would disconnect all ground so I couldn't short any of the positive lugs to the body/box. It would also prevent 'false ground' coming back through the voltage regulator/12V circuit.
Am I understanding this correctly??
I would install a separate fuse box for the 12v circuits but I did not include for simplicity.
I am trying to avoid a 24v to 12v converter as I have a 200amp generator that will balance the battery and don't plan many 12v circuits other than AC/heater blowers and TCM and maybe minimal radio.
I've included a last option that cutsoff the ground feed and also the feed between the two batteries. If I did this I would include a relay to cutoff 12V circuits so it can't drain the battery.......could even wire a 24V relay fed off the busbar with a ground connected to the cutoff so it does this automatically.
