Military Cutoff Disconnect Switch HMMWV Battery
SmartDrug
310
Saint Charles, IL
I appreciate your help with this. I have a much better sense of the electrical system now.
Regarding the switch, I’ve seen a handful with the same specs but different model numbers. I think I’m going to call Hella tomorrow to clarify.
I’m also going to take this opportunity to remove the slave port and the rear shelter power plug to clean up the box a bit.
nikojo
106
Wisconsin and Illinois
In your diagram you can wire it so you cut off the 'green' and leave the "blue" alone or as Mogman pointed out do it the opposite way. That effectively does the same thing assuming you cut off both switches. I like doing it my way by cutting off the interconnect between the batteries in case I added other 12V circuits in the future. That way I don't have to add any more to the switch.
The switch I used is 2 switches in one so it does it all together.
Chadwickadam
Arizona
Hey, I'm new here and this thread has been extremely helpful so thank you. I was wondering if anyone has tried this or knew the answer:
If you do the same setup as nikojo with a single dual pole switch but instead of interrupting the ground and battery interconnect, can you interrupt the ground and the opposite batteries hot?
If so, does this achieve the goal of total power shut off so nothing comes on?
Are there concerns with having the interconnect joining the two 12v batteries and then battery 1 hot and battery 2 ground going to the separate circuits of the cutoff switch?
Would I then attach the "out" pole from the switch to the hot and ground of the starter?
Thanks for the help
Mogman
10,530
Papalote, TX
Thanks for the help
Yes interrupting the ground and 24V hot would do the same thing, no current could flow in any circuit.
nikojo
106
Thanks for the help
The problem with this is that the 'high' side battery (running 12V) can still find ground through the voltage regulator.
Steven (RWH) pointed this out earlier in the thread.........."connection to the 14v tap off the regulator can and will also act as a ground when the ground is disconnected allowing the truck to be cranked over but on 12v only".
I would recommend cutting off the negative of both batteries, ie interconnect on high side battery and ground on low side battery.
If you do that there is no way for anything to get power.
But if you cut off the positive side on the first battery (high side) it will also accomplish same thing and isolate the battery bank.
Mogman
10,530
Papalote, TX
I would recommend cutting off the negative of both batteries, ie interconnect on low side battery and ground on high side battery.
But if you cut off the positive side on the first battery it will also accomplish same thing and isolate the battery bank.
I would like an explanation, if the 14V reg tap and trans tap cannot flow any current to the low side negative terminal because it is disconnected and it cannot flow any current to the 24v pos terminal because it is disconnected then just where would the current flow occur ?
Mogman
10,530
Papalote, TX
One of the first things a student in electronics/electrical 101 learns is that in order to have current flow one must have a path to and from the source.
Because the vehicle is not running the only source is the batteries.
A 12V battery in itself is a simple series circuit, 6 cells connected in series, removing any of the cells OR removing ether the positive or negative terminal will prevent any current flow through the battery.
The circuit below represents what the OP was talking about, since he has effectively removed the negative terminal from the low side battery and the positive terminal from the high side battery no current can flow through ether battery, effectively isolating all energy from the vehicle circuits.
50 years experience tells me the following is the preferred switch setup, I use the little weeny battery switches that some think are adequate for a main switch for the 12V and a 1500A Hella switch for the negative (24V) disconnect.
This way I can first isolate the 12V equipment then the 24V volt equipment with zero chance of reverse polarity of the 12V equipmewnt IE
12V OFF first and 12V ON last
There is no need to disconnect the large lead between the batteries, depending on if the 12V equipment is connected to the positive terminal of the low side battery or the negative terminal of the high side battery (works ether way) you can leave yourself unprotected.
nikojo
106
In that scenario, high side positive cut and low side negative cut then no problem.
But is you only cut the low side negative and tried to start the truck or turn on the lights........you would get flow from the high side battery (24V terminal) and then across voltage regulator (which now looks like ground) and through interconnect and to negative pole on high side battery.
Mogman
10,530
Papalote, TX
Yes, that is why it takes two switched (or a DPST) switch do properly safeguard the system.
The scenario above is what we were talking about.
Chadwickadam
Arizona
Just a random question: Is the TM procedure to disconnect the negative terminal before any electrical work sufficient to safeguard everything, or are there any chances things can go haywire?
In my limited experience this has been sufficient to be able to work on things you just have to be careful. I had the grounds detached and but leads attached and while working around the shunt area I ended up hitting the ground with the ratchet and completing the circuit. Lovely sparks and new engravings on my socket. Still better than when the lead battery terminal exploded into molten lead...if you live hopefully you learn haha
Mogman
10,530
Papalote, TX
If you only disconnect the negative terminal and then try to pull a 24V load, try to start the vehicle, turn on the lights etc. you can reverse polarity the 12V reg and transmission, they seem to have SOME tolerance for this but if disconnecting battery leads for maint I would also remove the 24V positive terminal off of the front battery.
I build Motorola radios for many volunteer fire departments that use surplus military vehicles and have had several instances where they use a ground only disconnect, jump into the vehicle and try to start it and fry the Motorola radio as they and most other 12V gear do not have ANY tolerance for being subjected to reverse polarity, given the cost of regulators and TCMs I would not risk it.
BTW the first time I would repair the radio for free, any more and they would have to pay.
86humv
544
Texas
I disconnect the Dog bone cable....positive at rear batt. and Neg. of front battery.
