springer1981
- 1,148
- 93
- Maine
LOL, nope "just a thought"Pffffft here I was thinking it was already tried and true by someone else![]()
I also decked the middle section from the doghouse to about 4 feet from the back where we have our sub-woofer box. We outlined the whole section and then made a cut out with wood. I dymatted the bottom and dyna decked the top. It made a huge difference. We did the same with the roof. 5 by 5 foot section of wood. Dyna decked the whole thing and screwed down the soft top. No issues, no flapping and no leaks.
Funny you mention the smell, in 1990 my wife worked at a VCM plant making the ingredients for vinyl, we purchased a 1990 chevy truck and she pulled a sample after it sat in the sun all day, ran it through the plant and it had 400 times the recommended exposure of vinyl (time weighted for an 8 hour period)Got some pictures by chance? This sounds pretty neat.
In terms of updates on my mat situation, they're doing great with the only downsides being 1: drainage, 2: slight rubber smell. I'll probably make a few holes for drainage and hopefully the new rubber smell wears off after a while.
heh that's always re-assuring, sounds like we're always in the best of hands with manufacturersFunny you mention the smell, in 1990 my wife worked at a VCM plant making the ingredients for vinyl, we purchased a 1990 chevy truck and she pulled a sample after it sat in the sun all day, ran it through the plant and it had 400 times the recommended exposure of vinyl (time weighted for an 8 hour period)
GOTA love that new car smell!!
Yes we all would really like to see pictures of this.I also decked the middle section from the doghouse to about 4 feet from the back where we have our sub-woofer box. We outlined the whole section and then made a cut out with wood. I dymatted the bottom and dyna decked the top. It made a huge difference. We did the same with the roof. 5 by 5 foot section of wood. Dyna decked the whole thing and screwed down the soft top. No issues, no flapping and no leaks.
So I pass the local Tractor Supply and go inside and I see the mats. Those would work well for floor mats. I ask the cashier if they have any that are bigger than 3x4 so I could also put something down in the bed as one piece. She directs me outside where they had some substantial mats that were larget enough for the bed for about $45. Picking up the things would give you a hernia! But they load them for me.Go to Tractor Supply and buy a thick rubber floor mat you find near the front doors. Usually 4' X 3', then cut it up to fit. Just a thought...
Heh that’s some dense rubber then, the smaller ones were already enough of a pain with a razor blade but the large one sounds like a taskSo I pass the local Tractor Supply and go inside and I see the mats. Those would work well for floor mats. I ask the cashier if they have any that are bigger than 3x4 so I could also put something down in the bed as one piece. She directs me outside where they had some substantial mats that were larget enough for the bed for about $45. Picking up the things would give you a hernia! But they load them for me.
Get it home and I went to work to trim it to size. First I try a 20V battery circular saw. Would not dent it! So I whip out my AC powered US made circular saw. Thing goes to work on it but in the middle it smokes the saw!This mat is beyond tough. I look at the receipt and it says "Horse Mat"
Exactly what I did, worked great. I was trying to cut in one pass at first but that wasn’t gonna happen.Like what jake20 said. We have a lot of guys using the horse mat for tool box tops here at work. I’m not sure on the thickness you all are using but the ones here used are around 3/4in thick and all we do to cut them is get a fresh razor knife and a guide or just mark your cut line. Then just lay the cut line off a edge of a table or something similar and start cutting it down the line in multiple passes it’ll start to cut separate and break over the edge of the table and then finish cutting it through.
I have had success with cutting horse stall mat with a worm drive circular saw with a "wet wood blade". We also put some dish soap on the cut line to lube the blade. Found if you don't the blade sticks in the cut, gets hot and warps. Works well for cutting used conveyor belting too!Like what jake20 said. We have a lot of guys using the horse mat for tool box tops here at work. I’m not sure on the thickness you all are using but the ones here used are around 3/4in thick and all we do to cut them is get a fresh razor knife and a guide or just mark your cut line. Then just lay the cut line off a edge of a table or something similar and start cutting it down the line in multiple passes it’ll start to cut separate and break over the edge of the table and then finish cutting it through.
Looks fabulous; well done!Finally got around to this, great recommendation. Hard to cut but worth it. I found that dragging a sharp razor blade along a straightedge like a square tube makes it easy to score. Once you score it, bend the edge over the end of a table and cut it until you’re all the way through.
Did the driver and both rear footwells. Haven’t gotten around to the front passenger seat yet.
I may cut some small holes in it for drainage through the existing floor holes, don’t want water/mud pooling up in the winter.
Jigsaw with a drop of oil on the blade every once in a while - easy peasy and cuts like butter. The edges also clean up very nicely with a round-over bit on a router.I have had success with cutting horse stall mat with a worm drive circular saw with a "wet wood blade". We also put some dish soap on the cut line to lube the blade. Found if you don't the blade sticks in the cut, gets hot and warps. Works well for cutting used conveyor belting too!
