Ok, I'm trying to figure out what I will need
Thanks for the video ADF
From what he is saying, or at least from what I understand, my gauge may not be getting any connection to the "signal" wire from the sending unit. As it shows way past full, around the 3 o'clock position just as he states. He stated something about "shorting" the gauge and if it was good, it would go back to empty. I'm not sure what he means by this... my guess is he means grounding the signal wire? Or grounding the "electrical stud" on the back of gauge that the signal wire connects to? If I can test the gauge in this manner, it would at least tell me if the gauge is working.
Also he shows a resistor on his fuel gauge connecting two of the "electrical studs" that connect to the printed circuit board. Is the CUCV fuel gauge supposed to have this resistor?? Because the last time I had the instrument panel apart, I don't remember seeing one. But my memory and recall is not good.
IF I can test the gauge and see that it is Able to work, thereby eliminating it as the cause. Then the next issues could be the signal wire and/or the printed circuit panel for the instrument cluster.
If I pull the instrument panel again, I was considering going ahead and replacing the printed circuit board since it is 40 years old. Eliminate future issues hopefully. And get one while LMC still sells them. From my searching, I am fairly certain that the correct one is LMC part
# 38-8036
I'll also get some new retaining clips that connect to the gauge and panel also. I think only the fuel gauge has those clips, so should only need 3.
Shop from thousands of parts and accessories to help you restore, maintain, and customize your Chevrolet, GMC, Dodge or Ford truck or SUV. Keep 'em on the road with the right part, right price, right now.
www.lmctruck.com
Was looking at the gauges on LMC also, if I end up needing to replace it. Pretty sure it's
# 36-1966
www.lmctruck.com
Why is it that the Diesel gauge is the
Only one that has "
circles" for
empty/half/full, instead of just "
E - F" ?? Do they think people using diesels can't read??
Would get one of the others that have E to F as they appear to mount the same, but they probably wouldn't read right or something. But hopefully I won't need a gauge to start with.
In any case, I'm going to try to test the gauge first. If I could get it to "read correctly" with the right wires being grounded or not, then that would at least tell me the gauge is working. So guess my next step is to figure out how to ground the signal wire... to bad I already reinstalled the tank.... and I just got my side step and the skid plate re-installed today. If I have to get to the sending unit signal wire, I'll have to pull all that back down again....
