Huertam96
- 12
- 3
- Houston tx
I’d like to know the correct engine oil type. I’d prefer to know what it is or what it’s suppose to be
I greatly appreciate your response! I’m new to this truck I’m trying to learn everything I can.The military would have used 15w40. I have always used that oil in every diesel I have owned, including CUCVs and HMMWVs with the 6.2L or 6.5L engines.
Thank you as well this very informative ! Y’all have a blessed dayRotella 15-w40 is what you will find at Walmart and just about any parts store. If no turbo I would suggest the T4 non synthetic. If you have a turbo or plan to let it sit for months between uses then the T6 synthetic might be better for your engine.
You can use any brand. I just know Rotella is stocked just about everywhere and is meant for diesels. Whatever you get make sure it says heavy duty diesel oil. That is the important walk away from this thread.
