Tire talk
juanprado
2,740
Metairie/La (N'awlins)
that is expressed in the ratings.
the higher the number, the harder the rubber and lasts longer hence more mileage.
Tires are rated for example 500/A/A
The letter grades are temperature and traction.
thoner7
157
NE TN
Interesting. I’ve never heard of such a thing and researching it, I can’t find any info on the tires I was considering at all
vmaxmike
17
WI
Google UTQG
you'll get an explanation
Tread wear is mainly about the tires durometer measurement ( hardness of the compound )
This measurement also changes with heat cycles.
M.
vmaxmike
17
WI
It short the lower the UTQG number the softer the rubber ( think sticky good for high speed cornering ) but they don't last.
The Higher the number the harder the rubber ( They wear much slower ) but they don't stick.
M.
87cr250r
1,907
Rodeo, Ca
I think the rating requirements only apply to P series tires, P315/85R17 and not LT series, LT12.5/37R17 for example.
GTUnit
152
CA
Just a PSA on tires with old date codes. On the trail in the dirt you can get away with almost whatever as long as its stays together and holds air.
On pavement is when things really change and it gets serious.
Old date tires on pavement at moderate to highway speeds are Dangerous. (speaking from research AND experience.. bad ones)
Rubber is always drying and breaking down (at different rates in different environments but this basic fact does not change)
In most cases it becomes Harder and less pliable/stiffer with age.
So in older tires all the factory engineered tire dynamics and performance change to where they the tire no longer performs as intended.
This may be a mild change (depending on age and chemical composition) like tire that used to grip from a standing start that now breaks loose and spins on acceleration. It may also be a more serious performance degradation where all the tires will break loose on a basic lane change or change in road elevtion that unsettles the vehicle and you will go spinning across the road into oncoming traffic at 50mph.
This will be worse on road cars. I haven't experienced it in a truck with offroad tires but the rubber issue is the same. Maybe a light rain or snow and you get wrapped around a tree.
Bottom line is if you plan on travelling on paved roads at speeds above say 40 mph I would not use old tires. It creates a pretty significant risk to you, family, other valued occupants. Truck is replicable but still not worth rolling those dice after all the effort that went into it.
gringeltaube
Staff Member
2,282
Montevideo/Uruguay
interesting.. What has happened that makes them universally "garbage"? ..........
HMMWV MT/R tires: Some go, some blow....
From my own experience: out of about 50 tires sold (all are LR "E" and dated 2008/2009) only ~10% of them have failed, so far.
They all start to develop cracks right here, just like this one:
I'm convinced that this happens mainly with the LR E tires (which have a stiffer carcass than LR D), when people put them on heavy vehicles, run them at highway speeds, at relatively low TP's. Plus the fact that old rubber just doesn't flex like when fresh out of the mold.
Besides that we don't know the history of these surplus tires. At the time when GL still used to sell these (by the hundreds of lots, each week) most of them came from HMMWVs which were cut up in pieces. Who knows for how long (maybe years) these vehicles had been standing stationary awaiting their fate, possibly even deflated some.
Gcelevator
583
Florida USA
I just pulled the trigger on some Black Rhino Abrams and Toyo open country AT. Tired of the jumping and wobbling around with the military tires.
fuzzytoaster
2,912
Fort Worth, Texas
View attachment 890299 View attachment 890300
Agreed. It helps that we don't carry around all the armor package weight and etc too. I have several hundred of the MT/Rs on rim dated 2016/2017 that are NOS. About half have never seen the ground until I rolled them around for inspection. I'm not afraid to use them and tire on rim with run flat is hard to beat for the buy.
mgFray
924
Southern Minnesota
So where is the best place to get a full set of tires and wheels?
Can't help you with the wheels, but if you want _NEW_ original Goodyear Wrangler MT (not R), any commercial goodyear dealer can now request them. My understanding is they are not directly orderable, but their rep can get them. (I ordered mine through my local Discount Tire. They would NOT mount them, but ordering was no problem. Took about 3 weeks for them to arrive. They were manufactured about a month before I ordered them.)
I don't know if the MT/R are available or not. They have a new 'enforcer' tire, it might be the replacement for the MT/R.
I wasn't able to find any place for the BFG Baja's new, only surplus.
Gcelevator
583
Florida USA
I asked my tire place/friend that takes care of all my commercial trucks to check them for me. He called me 3 days later and said they are not available from the manufacturer or any place. Supply is dry, i ended up ordering new aftermarket rims and tires. I wanted to keep the original look but to no available.
