ECO Hubs Who needs 3:07 gears?
Xengineguy
831
USA Indiana
I know I’m going to get flamed, but here we go. PLEASE DO NOT ASK ABOUT PURCHASING ACCEPT THRU PM.
I just finished an up grade to my 1078. DELEATED the hub 2:1 gear reduction. I built direct drive hubs that can be
installed in 20 to 30 minutes per wheel. Doesn’t harm the original reduction system,(that can be reinstalled in
20 to 30 min). NO shim changes, ( the shims stay in place).
The difference in noise and power is dramatic. The noise was 45 mph 80 db, 50 83 db, 55 84db, 60 85 db.
Now the noise is 45 69db,50 70db, 55 71db, 61 74db. This may not seem like a lot but it is! I now have wind noise
that I never heard before! I can hear my blinker click at 45 mph or below!
Now the fun stuff. Before the change my 1mph to 60 was 28 seconds! Now it’s 19.78. 1mph to 40 was 14.63
now its 8.75!
Before anyone comments that somehow I’m going to break axles, transfer case, rear end, etc etc. Consider that
all those components are designed to withstand the maximum torque of the engine plus quite a bit more .
The maximum engine torque is the same. The only difference is the torque to the wheel has dropped 50 percent
if you look at the gear ratio only.
In the near future I will test its ability to pull loads on trailer. If I had to guess this will Be much better performance than before. The engine is happy in the power band where it belongs.
I invite anyone with a Lmtv that’s considering a gear swap to come to NE Indiana and drive mine. You will be impressed! Yes I plan on offering a kit to do this conversion, firming up details now. The first run will be 12 sets.
The cost will be around 2200/ 2400.00 Each set. 4 hubs. If there is enough interest…. Sorry for the long post.374B80C5-39CC-4551-9192-7CF07A2C096A.jpeg58A3C8EA-DF2C-4001-9FD9-5BAB62921EEB.jpegC4B4E8E2-D01D-43AD-99DA-102C8B60B706.jpeg49605C8D-AC0B-4E45-BBFD-09091617154F.jpegFB281CA0-2963-4299-9B76-082C5E436DDB.jpeg
Anyone interested in purchasing a set, please post in the sales thread:
coachgeo
3,553
North of Cincy OH
interesting. With that quality work and your user name..... sounds like you are an engineer so went about it with a lot of thought.
Still skeptical though.... How small is the FMTV ring , pinion, thus pumpkin size, compared to say the axles in a Kodiak with same engine and Allison?
serpico760
1,887
San Diego, CA
now its 8.75!
The cost will be around 2200/ 2400.00 Each set. 4 hubs. If there is enough interest…. Sorry for the long post.View attachment 891540View attachment 891541View attachment 891542View attachment 891543View attachment 891544
Would be interested to know the results of towing, up hills, and mpg now. How much would a set for an M1083 be?
100 miles over a mountain and into the desert, 45 miles off-roading in the badlands, and 100 miles back, I got 4.4 mpg, emptied the 54 gallon tank!
GeneralDisorder
6,224
Portland, OR
The Meritor ring gear is 11.70" in diameter.
For a comparison - Meritor rates our axles at about 14,700 lbs for the front, and 15,000 lbs for the rear. About 7.5 ton's per axle. For the non-armored trucks in civilian ownership, most will be running in the range of 10,000 to 13,000 per axle fully equipped and loaded.
A good comparison here for a non hub-reduction axle would be the Dana S130 - the 14,000 lb variant being equipped with an 11.8" ring gear, and the 16,000 lb variant equipped with a 12.2" ring gear.
So realistically - with them being under loaded for our application and the usual over-engineering that has gone into them - being exceptionally under-rated due to their intended military application..... I have a hard time believing that a tenth of an inch is going to make any real difference.
Oshkosh is still using the same axles that are under our trucks on A1P2's with 4500 lb armored cabs and thousands more lbs of counter-weight in the back and not single F*ck being given or de-rating of their capacity to be seen. 🤷‍♂️
I'm definitely curious about this and would like some data on off-road performance, fuel economy, and of course longevity if that's even any concern..... any insight into calculations done or engineering put into them would be great.
tennmogger
556
Greenback, TN
A few questions for your very interesting experiment: what are road speeds at the shift points? Does the truck get into both overdrive ratios? Not having to trash a set of reduction gears has big benefits.
I am interested for an LMTV I use as a daily runabout. Hardly ever loaded on only mildly hilly roads.
PS, Coachgeo, sounds familiar, eh?
Guruman
Not so new member
494
1,076
Cody, Wyoming
Interested....
And to @coachgeo 's point....
All of the drivetrain components are engineered to take the full HP and torque that the engine delivers (more considering most of our engines are running at lower settings, but newer/different models are running more HP/Torque on the same axles). That's true all the way up to the reduction gears. Everything after that is designed for twice the engine torque output.
Removing the gear reduction does not place more load on the upstream driveline components. They will still only ever see the total engine HP and torque as before... right? And everything after the gear reduction )basically the hub and bearings) will only see half the torque as stock.
On paper this is a win-win.
I suspect the drawbacks are at slow speeds and heavy loads, where that additional torque multiplication is really handy. But for me it might be worth the trade-off. I'm not looking to plow through deep mud, or climb super steep hills offroad. As much as I hate to admit it, but 90% (plus) of my driving will be on the road going somewhere interesting, then maybe 10% easy forest roads to find a out-of-the-way camp spot.
@Xengineguy, I'm down near Muncie, and I have a Son that lives in Angola, so I'm up that way occasionally. If you need another test rig, I'm interested.
Xengineguy
831
USA Indiana
To answer a few of your questions. At this point the truck uses first overdrive only, my speed is limited by tire balance.
I will fix that in the future. I have only done a transmission relearn at this time, the shift points are now very good.
The harsh first shift is gone. I have an appointment to have the shift points set? And speedometer recalibrated this week.
As it is now I would saw most shift points are 1600 to 1750. Absolutely great around town, often turning 1200/1400
at 38 to 40 mph. You push the throttle a little and it accelerates quick without downshifting…. The other nice thing
the Truck coasts awesome! Nice light downshifts as you approach a stop.
Really liked driving my truck before, now I love it! Doing a 30 mile trip before I would think twice, now it’s like let’s go!
Im sure the mileage has improved, but I haven’t checked yet…
Xengineguy
831
USA Indiana
Interested....
You need to contact me and come up and drive this truck. You will be very surprised at the power it has. I think it’s the perfect combination for what you describe and more.
Xengineguy
831
USA Indiana
A little more info for people reading along.
The drive hubs are made from 4140 steel , machined ,Holes drilled then heat treated to 55/60 Rockwell.
Then wire EDM splined at 20 to 30 percent tighter than stock axle/gear fit.. This is a costly way to do it
but provides very consistent parts. The adapter plates are lazer cut, tig welded then the id machined.
After that they go to the CNC and get drilled and drill tapped….
Will post more as I continue to test and enjoy my m1078.
DeMilitarized
1,127
Gainesville, GA
At what speed do your tires limit you?
