- 753
- 1,331
- 93
- Highland, Indiana
Luverne style grill installed today after much fabrication work to mounts.
![](http://uploads.tapatalk-cdn.com/20230305/6664defc5515583f52963ea4872fcafd.jpg)
![](http://uploads.tapatalk-cdn.com/20230305/12a90d1b62c4eee0606df6d2c836bf12.jpg)
Was the IR light pretty easy? Ran to a separate switch?Installed new headlights, and swapped the blackout driving light for an IR light
I did have to modify the bracket and hood slightly to make it fit. There are several ways it can be done, and I don't think I did it the best way honestly lol.Was the IR light pretty easy? Ran to a separate switch?
I think I would have mounted the mud flap on the front of the bumper so the Rhino mount would be flush with the bumperRhino tire carrier installed. Just need to find a wrench to mount where it's missing. And a 24 bolt rim to match the others.![]()
I put a few washers behind the left mounting bolts to compensate for the flap. I've seen them both ways.I think I would have mounted the mud flap on the front of the bumper so the Rhino mount would be flush with the bumper
Lol that's the way I did mine.
Mark
Very cool. What radjo is that?some interiour work donw... middle console
made out of a M933 Container
.some interiour work donw... middle console
President Berry 2 with a biiiig amlifier behind on a simple 2.5ft antennaVery cool. What radjo is that?
Cutting, grinding, weld, repeatYeah the console is impressive. Just what did you do to make it?
Mark
That looks pretty slick. How did you mount the console, any special considerations or fasteners?some interiour work donw... middle console
Sounds like a rivnut or a pem nut perhaps?Dont know how it called in english... you dill a hwole and press in a nut. So i can remove it with two screws and still have a flat surface. The screws are in the lockable compartment, so that it can not be easily stolen.
Looks good! Did you use the brackets that came with the brushguard and cut & drilled on one side (the outside)?Luverne style grill installed today after much fabrication work to mounts.![]()
