Pstyckiewicz
- 91
- 28
- Massachusetts
I have an M1152A1 with the 2 wire compressor. I noticed that the A/C is not working. The fan runs fine but no cold air. I looked at the clutch on the pulley and it’s not engaging. I attempted to test the voltage to the compressor but I didn’t yield any result. Also let it be know I have no idea what I’m doing testing wires or how my tester even works. Mechanical inclined but wiring I’m lost. Not sure if the A/C/heat switch is working either. I haven’t ran the truck long enough to tell if the air is getting warm. I opened up the gauge cluster and everything appears to be connected behind there. Any advice where to start would be greatly appreciated!
A/C model RCSK1756-7
