Cluongo
- 3
- 3
- Lancaster Pennsylvania
Initially the TCM gave me code 73 when I put it in diagnostic mode by jumping A and E on the 6 pin plug. Now, it does not throw any codes. I suspect that's because the TCM was unplugged.
Is this something a transmission shop would have? Or is that something the modus can do? Remember the only way I can read the tcm is through the obd1 port I wired up. I would imagine I can't do the normal things a modus could do with just that setup..You should be bypassing the TCM and using the snap on tool to act as the TCM, thus eliminating the transmission as the Culprit
The TCM itself is the same as used in the civy vehicles, over 1000 for sale now on Flebay, again I would look for the hardware number as I showed in an example above to see if there are any with the same number first. (search for the number on your TCM, not the eprom)I would definitely buy another TCM from ebay if I could find one cheap. The cheapest I've found are $600-$1000.
The tcm is not throwing any codes when using the modus.Again what code/codes is the TCM throwing?
The only code it ever threw was 73 with the original TCM. That code is for the PCS (pressure control solenoid) circuit. Thats what led me to replace all of the internal solenoids and internal transmission harness. When that did not fix the issue, I found the troubleshooting manual online and began checking wiring. Couldn't find any issues there. Thats when I started looking at the TCM as a suspect.So if you drive it with the old TCM in it, it stays in limp mode and does not throw any codes when the pins are shorted together? I have no idea weather the modus is/can work properly with the setup you have and no ECM.
This is something that is important. If you wish to make up an extra and sell it I'm interested. Would be great to be able to have a regular shop connect. Just let me know if your interested. Dave 8325386328This is the adapter I made to go from the 6pin cannon plug on the tcm housing to an OBD1 port.View attachment 896345
Mine is doing the exact same thing. What did you figure out to fix the issue??!!The only code it ever threw was 73 with the original TCM. That code is for the PCS (pressure control solenoid) circuit. Thats what led me to replace all of the internal solenoids and internal transmission harness. When that did not fix the issue, I found the troubleshooting manual online and began checking wiring. Couldn't find any issues there. Thats when I started looking at the TCM as a suspect.
It has not. I will try to find it today and test. I am assuming at this point its a bad TCMHas the neutral safety swithc been cHecked?
What would the neutral switch have to do with the transmission? it is only to prevent starting in gear.Has the neutral safety swithc been cHecked?
A faulty switch can cause many issues. Yes, its function is safety starts, but they have been known to cause other issues, when they are malfunctioning.What would the neutral switch have to do with the transmission? it is only to prevent starting in gear.
The above is what prompted the question of the neutral safety switch. This condition can be caused by this.......intermittently.The 4l80e had an intermittent issue where it would randomly go into limp mode.
The neutral safety switch is in the shifter and has nothing to do with the range switch that is in the transmission.A faulty switch can cause many issues. Yes, its function is safety starts, but they have been known to cause other issues, when they are malfunctioning.
With a scanner you can see if it is working simply by selecting the gear, and you will see the change on the scanner............and intermittent issue, could be detected while driving, with a scanner hooked up. It may not shift quickly, or switch from gear to gear without command.
ok, but you are wrong, sorry. It is not "in the shifter"The neutral safety switch is in the shifter and has nothing to do with the range switch that is in the transmission.
It only prevents starting the vehicle unless the shifter is in neutral and or park in the case of a 4 speed and has no connection whatsoever to the transmission wiring.
