4l80e head scratcher.. need help
Cluongo
Lancaster Pennsylvania
Initially the TCM gave me code 73 when I put it in diagnostic mode by jumping A and E on the 6 pin plug. Now, it does not throw any codes. I suspect that's because the TCM was unplugged.
Cluongo
You should be bypassing the TCM and using the snap on tool to act as the TCM, thus eliminating the transmission as the Culprit
Is this something a transmission shop would have? Or is that something the modus can do? Remember the only way I can read the tcm is through the obd1 port I wired up. I would imagine I can't do the normal things a modus could do with just that setup..
Mogman
10,602
Papalote, TX
I would definitely buy another TCM from ebay if I could find one cheap. The cheapest I've found are $600-$1000.
The TCM itself is the same as used in the civy vehicles, over 1000 for sale now on Flebay, again I would look for the hardware number as I showed in an example above to see if there are any with the same number first. (search for the number on your TCM, not the eprom)
Mogman
10,602
Papalote, TX
So if you drive it with the old TCM in it, it stays in limp mode and does not throw any codes when the pins are shorted together? I have no idea weather the modus is/can work properly with the setup you have and no ECM.
Cluongo
The only code it ever threw was 73 with the original TCM. That code is for the PCS (pressure control solenoid) circuit. Thats what led me to replace all of the internal solenoids and internal transmission harness. When that did not fix the issue, I found the troubleshooting manual online and began checking wiring. Couldn't find any issues there. Thats when I started looking at the TCM as a suspect.
Mogman
10,602
Papalote, TX
looking into this brings up the question about TCM compatibility, it would really help if some folks would give me the part number on their TCM itself so I can do more research.
loosegravel
Just a retired mechanic who's having fun!
504
893
Enumclaw, Washington
What about the two external speed sensors. You mentioned replacing the internal harness and all of the internal sensors. Is there possibly a problem with the external speed sensors or the twisted pair wires to each?
Mogman
10,602
Papalote, TX
I am 100% wrong, yet almost right.
The most common 4L80E TCM, like 99.99% of them out there are not compatible, the same TCM was used on some early civi 4L80Es but they are scarcer than hens teeth.:(
Rpaint82
kansas city mo
Mine is doing the exact same thing. What did you figure out to fix the issue??!!
155mm
Chief and Indian
507
Guymon, OK
this is my code 73 fix thread, try disconnecting batteries, and before starting vehicle test for a fault code.
Rpaint82
kansas city mo
Keep running into the same transaction issue.. my TCM is giving me the Pressure control solenoid code.. ive replaced the PCS , all the solenoids, internal harness, and TCM.. drove all over yesterday no issue. This morning transmission light back on with PCS code..loosing my mind with this !! Only thing i haven't replaced was the external harness from the transmission to the TCM. 09 M1167 Rev
66
21
NC, USA
What would the neutral switch have to do with the transmission? it is only to prevent starting in gear.
A faulty switch can cause many issues. Yes, its function is safety starts, but they have been known to cause other issues, when they are malfunctioning.
The 4l80e had an intermittent issue where it would randomly go into limp mode.
The above is what prompted the question of the neutral safety switch. This condition can be caused by this.......intermittently.
With a scanner you can see if it is working simply by selecting the gear, and you will see the change on the scanner............and intermittent issue, could be detected while driving, with a scanner hooked up. It may not shift quickly, or switch from gear to gear without command.
Mogman
10,602
Papalote, TX
The neutral safety switch is in the shifter and has nothing to do with the range switch that is in the transmission.
It only prevents starting the vehicle unless the shifter is in neutral and or park in the case of a 4 speed and has no connection whatsoever to the transmission wiring.
21
NC, USA
ok, but you are wrong, sorry. It is not "in the shifter"
In 4l80es, the NSS is on the driver side of the transmission. It is a large black component with a large electrical connector or several I have owned several, and had similar issues. Limp mode can be enabled with a fault in this switch. Safety thing, go figure.
Further @Mogman.........if you know the NSS is not the culprit, then what would solve the OPs issue?
