6.5l TD engine valley clean up q
rcamacho
818
Bainbridge Island Wa
I need to clean up the valley to remove an accumulation of sand and clear the drain. Also need to validate the IP and feed hoses are no longer leaking (hoses and IP lines were loose).
Q:
Access is really limited even with the intake tube removed. What’s the best way to gain access?
Contemplating removing the turbo to gain access from the passenger compartment.
  • Like
Reactions: OBX
rcamacho
818
I was able to get a vacuum hose nozzle into the valley and clean out a few lbs of diesel laden sand. Much more cleaning is needed but it’s a start.
rcamacho
818
Still can’t quite get a view of the drain from the top of the engine with the turbo in place. If anyone has a good link to a picture of the valley side of the drain that would be appreciated
rcamacho
818
Good news confirmed no leaks from the IP after some extended driving. Looks like I have leaks from the RT return lines which I have not yet serviced.
Additionally #3 injector appears to be leaking from the main body. I’ll validate that and rebuild or replace.
