VIC-3 whistling noise with Engine rpm
engele
Nagold / Germany
Hi,
i have a VIC-3 full station in my Humvee.
i have a whistling Noise in my headset depending the rpm of the Engine.
only in Live, VOX or PTT if the PTT is on.
anyone have the Same issue? I think its Not normal.
greetings
milradioman
Kooskia, Idaho
Sounds like alternator whine, which may be a defective alternator, (bad diode?) it may charge ok, but still cause the whine.
Where is the power connected?
Check grounding location(s)
You could install a filter, but better to eliminate the source of the interference.
US6x4
2,440
Wenatchee, WA
I have that same sound in my M813's VIC-1; kinda sounds like the truck has a turbo. Would a filter simply wire inline with the positive cable for the 1780 amplifier?
Augi
42
SF Bay Area
Try improving the grounding. I ran a big flat ground braid from one of the feet of the main control box back to the battery and it reduced the whine significantly.
Augi
Augi
42
SF Bay Area
I'm talking about the CD-82 for the VIC-3. You can try the same with the AM-1780. Remove the paint where you attach the ground strap.
Augi
86humv
539
Texas
I've tested the vic-3 on a bench power supply...and had a whine when only positive and negative were hooked up...then I grounded the main control box to the chassis ground wing nut on bench supply....no more whine.
RJTM998
374
North Carolina
Side note: I added a 6 gauge ground cable back to the battery and that cured the whine in my VIC-1.
I tried this and it didnt work. I have been chasing this whine thing for almost a year. I was hopeful this would fix it. I have installed a filter that helped a little, I have grounded to different positions from the battery, the shunt, the engine block, and still no luck. At this point I am guessing a bad diode in the altenator.
RJTM998
374
North Carolina
FWIW...I ran my ground cable from the AM-1870 attaching bolt (1 of the 4) to the same battery ground terminal that the AM-1870 power cable was wired to.
I put both grounds to the shunt. Not sure if moving both to the battery will help but may try that. What's weird about mine is it is worse sometimes than other times.
RJTM998
374
North Carolina
RJTM998
I figured out the alternator whine. When I mounted the crew boxes I screwed them into the wood on the tunnel but got into the actual metal floor and caused a ground loop. For those with this problem check your mounting points. Once I removed the screw that was touching the tunnel through the wood it went away. You might need to insulate your mounting points so no metal to metal contact.
