Power hookup for accesories
Doug D.
27
Winterville Ga
trying to hook up a back up camera and place for USB hookup. Best place to get power from? Best item to use to convert to 12volt? Where to mount buss hookup? i assume buss is a place where you can hookup multiple items?
  • Like
Reactions: OBX
Coug
4,765
Olympia/WA
What generator do you have? If it's the 60 amp you'll definitely need a voltage converter. If a dual voltage unit, you can hook to the rear battery for small loads, but they won't be switched with the ignition.
The Orion 70 amp 24-12 converter has a built in relay, so you can hook it to the batteries, then wire the relay to any switched power source. With a 3 speed truck that would probably be the fan controls, in a 4 speed the transmission relay input behind the battery box.
You can also buy USB outlets that work off of 24V input, and wire them into a live circuit of the truck. if only USB they should be low enough draw as to not cause problems. One favorite place to wire in small loads like this would be the horn circuit, as it's only live when the light switch is in service or drive positions.
juanprado
3,175
Metairie/La (N'awlins)
there is an aftermarket slave plug that has 2 USB ports.
I use it for my phone and simple accessories. Looks OE also
Mogman
10,496
Papalote, TX
Does that plug into the diag port??? although $100 shipped seems a little high to look cool
juanprado
3,175
Plugs into the slave outlet. Has a 24v inverter built in with overcharging/heating Circuit protection.
Simple solution to run low amp usb devices.
It is a veteran owned company and no more wires or drawing from rear battery inbalance seemed to me worth the price.
Cheaper solutions out there but no extra wiring or installing a fixture was a win for me.
Ymmv
