- 253
- 530
- 93
- Portland, OR
The full weight of the cab is supposed to be borne by the pins circled below in red. The adjustment procedure is to basically completely loosen the cab latch where it attaches to the back of the cab, lower the cab until it is fully resting on the pins, then tighten the top latch bolts, lift the cab again to tighten the bottom bolts. The latch exists simply to hold the cab down, not to support its weight.What do you mean by the “two pins on the side of the air ride frame?
![IMG_1438.jpeg IMG_1438.jpeg](https://www.steelsoldiers.com/data/attachments/654/654272-9350012fbea0a364f14426d7291ba332.jpg)
