ramdough
- 1,730
- Austin, Texas
My coolant line from the tank to engine is too short to fit my AC compressor into place. It would rub on the serpentine belt if I moved it.
The TM calls it:
Rubber silicone class Q 1” 400lb rated.
I found 50psi rated silicone hose.
Any thoughts?
Also, probably should swap the Home Depot fittings out at the elbow.
The TM calls it:
Any thoughts?
