- 1,550
- 1,800
- Puget Sound, WA
OK, so the big alternators have a 12v output, but where physically is there 12v inside the cab? Is there a line to the battery box somewhere?
they are OEM, I have them in all my REV trucks…came that way.I think someone added that to charge Thier phone.
There was a company I found that was using the same style housings for the STE/ICE and putting in a standard car socket or a standard USB charger socket. (How standard? It was the same size sockets you can buy on ebay for a few dollars, only the housing was a bit unique.)
I'm not saying that is what it is in this case, but don't let the housing fool you into believe it is real (or not). You'd need to identify if there is an NSN / CAGE on the part and see if it was something orderable or not.
Welcome to the SS forums!Hello all
310000+ serial number M1165A1 ECV
1 - Would like input on best place to pull 12/14V from for powering reverse switch on shifter?
2 - Location to pull power for any other auxiliary 12/14V needs?
3 - Removed the 400A alternator and put in 200A Niehoff alternator - I removed the positive cable feeding from the back of the 400A to the starter stud.
The negative I am considering leaving it in place as a supplementary ground (attached/on top of braided ground strap on alternator and terminates on a stud on exterior of the battery box underneath the truck) - is there anything wrong with leaving it in place?
Hello all
