TM for PU-821/T, PU-822A/T power plant
FMJ
37
Las Cruces, NM
PU-821/T, PU-822A/T power plant SCORE!!!!
Does anyone know the tm number for this?
Towbarman
14
North Little Rock, Ar. U.S.A
I have an issue with a PU 822A/T. No power to the ECU. I checked the fuse and it's good. Changed the regulator, still the same. Do I need to look inside the junction box at the generator it self and take readings there? the unit says" ECU is stuck in heat mode. Thanks.
Tinstar
1,947
Edmond, Oklahoma
Start your own thread for your machine.
It will help get you the answers you need.
