- 876
- 1,375
- 93
- La Crosse, WI
It has the bayonet plug on the top of it, also has the multiple battery shut off points (physical one beside the battery box, switch driver side kick panel, switch right side of engine bay)take a picture of the finned electrical gizmo behind the tire that the heavy wires go to. Post them up in here. Am curious what they put on it. From pics think we can tell If it is an LBCD or a standard Rev. Polarity protection device. 100amps usually only had Reverse Polarity box. Granted if you have the two means to shut off batteries (one on the metal box beside the batts, and one on kick panel...... then you likely have the LBCD
It's going to be an LBCD. The PPD went away long before 2007 - LBCD being introduced with the A1's right around 1999-2000. The LBCD was designed specifically because of the 100a alternator limitations. That's really it's only purpose - to protect that tiny alternator against the potential of the huge battery bank pulling too many amps off it. The newer style VR in his picture has the AC terminal that sends RPM data to the LBCD. So he's going to have an LBCD - no question on that.take a picture of the finned electrical gizmo behind the tire that the heavy wires go to. Post them up in here. Am curious what they put on it. From pics think we can tell If it is an LBCD or a standard Rev. Polarity protection device. 100amps usually only had Reverse Polarity box. Granted if you have the two means to shut off batteries (one on the metal box beside the batts, and one on kick panel...... then you likely have the LBCD
