2 Hole Injector Nozzles - Great Deal
Computerdoc08
220
Florida
Greetings,
I am not sure if this I the correct area to share his, but I found some 2 hole injector nozzles for a great price.
$4.25 each, shipping wasn’t too bad for me, added about a dollar per unit for the batch I ordered.
Hope this helps some of you guys out.
Adrok
197
Rochester NY
Newer member giving a bump to this thread.
I'm in the process of doing a LOT of work and addressing 10 years of neglect to a 68 Non-turbo C.
How have these injectors worked for anyone?
Improvement over stock?
Any issues using new parts with mixed fuel types?
Thank you in advance for any responses, guidance, or thoughts.
cattlerepairman
3,520
NORTH (Canada)
2-hole injectors superceded single hole injectors at some point in the multifuel manufacturing process. The 2-hole injectors cause fuel to burn more cleanly with less smoke and are said to reduce stress on pistons compared to the single fuel stream nozzles.
I have run both; the single hole injectors do smoke more, the two hole injectors sound different. Is it an "improvement" over stock? For power, I would not think so, but a better burn is good.
Adrok
197
Rochester NY
Thanks for the reply!
Any issues running mixed fuel product ( UEO, Vegetable Oil ) with the 2-port injectors? If it inherently promotes more complete combustion and puts less stress on the pistons, I may move forward with it.
Thank you again. I try not to resort to universal knowlege when working on this truck. Just because something works on a Ford Diesel does not means it universally applies here. lol.
