ger84
- 26
- 18
- Clinton, NJ
Hi all-  Currently I have a M925a2.  Great vehicle however looking to use this truck a little differntly. mods?
-I need a dump (which I am thinking of get modified to be a dump) (I know it can only hold half of what a normal m917 can hold....)
-be able to tow but it doesn't have a Jake Brake which makes me weary on towing and hauling especially in the hills that I live around in NJ. (can't find a jake brake for this application and then a $ install)
-I like the m917 but with that cat trans 16 speed- semi-auto model d-7155 overdrive I am weary of since nobody can work on it. (just replace it $) I like the tag axle for extra hauling and the 8x6 option. I have not seen any trucks with the automatic transmission...( Allison HD4070 is the 7 speed) I know that the cat trans lets the truck go fast but I don't need fast. I don't want issues.
Anyone have ideas?
Thinking of a HET m1070 and modifiying to have a dump bed. I also like that it can hold more that 2-3 ppl in the truck but not a deal breaker... (like i said not looking to go fast but reliable to and from and tow and haul anything) but.... also heard that with the M1070 the portal axles can heat up and that the air suspension has to be tuned up to be able to use as a dump truck but also worrysome as unstable with the airbag suspension...
Want to keep with the military version type vehicle- Don't want to break the bank-
I really want to be able to haul easily-
I know I can get a normal dump truck (i have a cdl lic) but common there has to be a good option out there....
Thanks for any options and ideas and thoughts...
Anyone have ideas?
