MEP 805B problems. Will pay for technical help
FarmingSmallKubota
1,248
Wapakoneta, Ohio
I think your jumping the gun in chucking parts. From your videos your not to the point of start but no run. It only cranked with the dead crank which will never start the engine. I think your in need of some deoxit(contact cleaner) and a little more studying of the TM trouble shooting procedures. See Guyfang post # 13
155mm
Chief and Indian
443
Guymon, OK
here is a thread to read thru for the Magnetic Pickup Unit, MPU
Chad Lares
44
San Tan Valley, AZ
Not very reassuring, read that thread and it looks like he never got his 805b working...(insert expletive here).
155mm
Chief and Indian
443
Guymon, OK
so that thread is for you to learn mpu testing, adjustment, removal installation and provide a way and part numbers to get you a new one if needed.
The OP never responded if it was fixed or not, you could ask the OP @GIJoeCzar if he got it running, that thread took from May to Sept to work thru
Did you test your mpu?
Your response to @peapvp was 'no change, no lights' does that mean you have no lights on backplane and each component?
For your cursor isssues, attempt to unplug, and replug the key pad to the display unit, its a serial connector, an old style serial mouse will also work
Did you check the wiring harness' that plug into the backplane from the engine side, verifying the collars are tight?
Chad Lares
44
San Tan Valley, AZ
I'll give that a try for the cursor. I'll pull that magnetic plug tomorrow. The batteries are fully charged now but no change to anything...
peapvp
1,341
Basehor, KS
I posted in Post #23 three diagrams. These three diagrams show the LED status at three different times, depending on the Switch Setting as indicated in the Box labeled: "Status" with a pinkish red background.
We have found that most users who have been presented with these diagrams go into a mental overload and their brain catches fire, thanks to 10+ years of Social Media, Pod Cast's and Smart Phones.
Can you report to us, based on the first two diagrams of what the LED's show when the Switches are set as indicated in the 'Status" Box
Thanks
P.S. These diagrams are in the TM and each LED is explained there in more detail
Chad Lares
44
San Tan Valley, AZ
Thanks
I'll do a video so you can make sure I'm following the correct procedure.
Chad Lares
44
San Tan Valley, AZ
Thanks
peapvp
1,341
Basehor, KS
These are the most erratic video's I have ever watched.
Now, in your Video Part 2, you went over the Governor Controller so fast, that we could not see whether LED 15 was on or off
The next question would be: What position was your Dead Crank Switch in (S-10)?
At least in Video Part 2 you figured out to look at the ECS, which is the Engine Control Switch S1 instead of the Governor Controller DIP Switches.
Out of curiosity, what do you do for a living?
Chad Lares
44
San Tan Valley, AZ
it is in Normal
peapvp
1,341
Basehor, KS
Now let’s take a closer look of the Status Box in Diagram #2
It says:
(S3) Master Switch: On
(S1) ECS: Prime & Run
Engine stopped (implying we have not started the Generator yet)
(S10) Dead Crank Switch: Normal
it is in Normal
You need to step back, take a deep breath and slow the f…. Down
then read everything in the Status Box, question yourself if you understand it and then look at every LED in the diagram
A red circle means LED is on and the color is red
A green circle means LED is on and the color is green
LED’s with black circles or no circles are Off
peapvp
1,341
Basehor, KS
Then you compare the diagram in respect to the LED statuses and note any difference between of what you see in your cubicle and the diagram after you set all switches as indicated in the status box of the diagram
