- 446
- 1,066
- 93
- Wapakoneta, Ohio
I have looked in the tm section under Generators and Misc, and trailers and did not find what i was looking for.
I need TM 11-8340-250-12&p.
I bought this unit a year ago and just now decided to mess with it. Mostly did not play with it because the giant tent sections block the back door to the Generator. So this thing is a 2013 has 600 hours. I know the HVAC unit does not have r407c as it says its been removed. so that will be for another day. 18kw Generator 3 phase. DRMO had Red x's on all sides and i see now GOV planet has increased starting prices of them more than what i paid total.
Anyway all fluids except Coolant were drained. Batteries are probably toast. I tried charging through the NATO plug when i got it, but did not work. I have 2 12v chargers on the batteries now, but usually they do not come back Group 34 AGM batteries surprisingly not Optima's this time. added oil and Diesel. brought over a good running mep 802a with slave cable and followed the start up procedure on the door. She sputter and puffed a little smoke till the air came out of the fuel system and she sprang to life. This is one quiet unit.
My thoughts on the unit will probably to never use the tent, but maybe cut a hole in my shop and help with the heat or air system when i am working in there or send it down the road. Just fun when they fire right up. Tomorrow I will be painting over the red x's just for.
