Poccur
- 134
- 43
- Roanoke, VA
Well you should change the filter dryer for sure if it lost charge, but the hole in the compressor could be patch welded...pull a vacuum on it and see what you have, if it holds...then put a Nitrogen charge in and see if it holds.....then, then start to think about putting some 407c in...I have a all the Hvac tools and the R407c to put back in it. but Just going to see how much hassle all of this is. Also with this being Winter its not enough ambiant heat outside to really get the moisture out. Edit. just realized the Compressor has had a hole drilled in it as well, so i guess i will end this thread and probably scrap everything but the generator. Thanks for all the replys
