If so, put a valve in the line so you can turn the air on when/if you want to pressurize the axles.That is what i have read and probably will, though it is nice to have options and there are places i could see wanting to go that those parts would be under water for a few minutes
I think the problem is, if the new boot does not have an air connection, then the turning on the valve is not going to make a difference. I guess I need to crawl under my SEE once the snow melts as I did not know there was an air connection on the bootIf so, put a valve in the line so you can turn the air on when/if you want to pressurize the axles.
That makes two of us.I guess I need to crawl under my SEE once the snow melts as I did not know there was an air connection on the boot![]()
Today I wanted to use the SEE that gave me all kinds of grief (fuel system, primarily) when I first got it. The wipers didn't work, either.
So what? These Unimogs are great.
Thinking more about it, I'm no sure I've ever tried the wipers before.The wipers didn't work, either.
