FLU419 SEE HMMH HME Owners group
brandan34
45
Southern Oregon
Has anyone replaced the boots on the axle shafts? I have one of the axles loose and I am now stuck. I do not see anyway to get the one piece boot that the military used over the ball on the axle tube and into place. Is this a case where I get some tire changing spoons and force it or is there a trick? I have not find where this is changed in the manual, every other part of the tube and tranny, but not what they call the bellows.
brandan34
45
Southern Oregon
I am starting to see why they do that. If you use the split kind it does not have a spot for the airhose when you turn on the 4x4 and there was another reason that i forget now that ei thought like orginal was better. I do have a help ticket in with them. At this point i do not see it an obvious way other than force.
brandan34
45
Southern Oregon
That is what i have read and probably will, though it is nice to have options and there are places i could see wanting to go that those parts would be under water for a few minutes.
brandan34
45
Southern Oregon
peakbagger
350
northern nh
If so, put a valve in the line so you can turn the air on when/if you want to pressurize the axles.
I think the problem is, if the new boot does not have an air connection, then the turning on the valve is not going to make a difference. I guess I need to crawl under my SEE once the snow melts as I did not know there was an air connection on the boot ;)
The FLU farm
1,473
The actual midwest, NM.
Today I wanted to use the SEE that gave me all kinds of grief (fuel system, primarily) when I first got it.
After it sitting for maybe three months, including in -22 temps, I didn't really know what to expect. Well, it started up instantly - once I remembered that I have to push in the switch on the clutch by hand on that one.
That the temp gauge didn't seem to work didn't bother me. Or that it eventually went up to quite high, then down to normal. The wipers didn't work, either.
So what? These Unimogs are great.
MogPoggers
95
Jamestown, New York
You guys may have seen a camo FLU419 with ripper bucket and new Pirelli Pista 22 tires for sale in Marengo, Ohio recently... and you may have noticed that the Ebay listing is no longer active. That's my doing. A deal has been struck and I will be in your exclusive little club very soon :)
I'm currently working my way through all 270 pages of this thread, along with the operator and technical manuals. See you in a couple months.
MogPoggers
95
Jamestown, New York
Does anyone have thoughts on a rear PTO? Beyond it's normal uses, I want to use the FLU to run a haybine, tedder and hay baler. I'm not sure how accessible the existing rear PTO is, even with the backhoe removed - but even if that's feasible, I'd rather not do it. I will be using the hoe often, so I'd like to leave it attached.
I was thinking I might weld an attachment point for a hydraulic PTO to the bottom of the backhoe, above the pintle hitch and then tap into the tool/extension hydraulic system and run lines back to it so I can use the PTO while the backhoe is in the stowed position.
The FLU farm
1,473
You won't be able to run anything meaningful off the front hydraulics.
I ran a snowblower off of the rear hydraulics for a few years, but if I did it again I'd put valves in the circuits instead of having to switch the quick disconnects for the backhoe twice a year.
