Many tks for the super quick response. Yes, I’ve followed the maintenance manual, but it doesn’t specify what other parts of the engine do I need to remove before removing the actual pump.. I can’t reach the 2 bottom screws…Are you following the procedure as outlined in the maintenance TM?
Struggling? How?
Godspeed131, you are great. Your help was very much appreciated. Indeed I had missed the (prior) instructions on top of the page pointing to other things that had to be done before. My bad.Everyone in some way or fashion will have their own shortcuts and so on but if your wanting to follow the TM to the letter, look under the equipment conditions at the top of that task, on that last pic you posted. Where it states that the injection lines are to be removed. If you go to that task stated out in paragraph 16-4 it'll again state the equipment condition at the top, and prior of removal of the injection lines you need the left and right manifolds removed. that should give you all the access you looking for, if you've not already removed them. After stating all of this, if you've already done or figured that out just ignore me completely lol. Also not the best pic but here is a pic of the access will look like without the manifolds
