M1151A1
Mastherr
13
Miami, Florida
Folks, my M1151A1 cranks but doesn’t start. Followed the military troubleshooting manual to the “t”… got to the fuel injection pump being the issue.
Any one has replaced it? I’m struggling so badly to remove it !!!!!
all internet videos are for the 998 ;-(
HoveringHMMWV
1,321
AL
Are you following the procedure as outlined in the maintenance TM?
Struggling? How?
Mastherr
13
Miami, Florida
Struggling? How?
Many tks for the super quick response. Yes, I’ve followed the maintenance manual, but it doesn’t specify what other parts of the engine do I need to remove before removing the actual pump.. I can’t reach the 2 bottom screws…
Godspeed131
968
Knoxville, TN
Everyone in some way or fashion will have their own shortcuts and so on but if your wanting to follow the TM to the letter, look under the equipment conditions at the top of that task, on that last pic you posted. Where it states that the injection lines are to be removed. If you go to that task stated out in paragraph 16-4 it'll again state the equipment condition at the top, and prior of removal of the injection lines you need the left and right manifolds removed. that should give you all the access you looking for, if you've not already removed them. After stating all of this, if you've already done or figured that out just ignore me completely lol. Also not the best pic but here is a pic of the access will look like without the manifolds
Mastherr
13
Miami, Florida
Godspeed131, you are great. Your help was very much appreciated. Indeed I had missed the (prior) instructions on top of the page pointing to other things that had to be done before. My bad.
Thank you very much for the picture, it makes total sense now. Will work during the weekend!!!!!
Godspeed131
968
Knoxville, TN
I’m glad it helped. If you’re not used to the tms, there is a set of growing pains a person has to go through to get proficient at them. So don’t feel bad.
Good luck on your endeavors!
Towbarman
14
North Little Rock, Ar. U.S.A
Have fun removing the hard fuel lines on the back of the injector pump. You will be using a crow foot to loosen the nuts. Also the bolts inside the timing cover.. # bolts are in there. Have to bump the engine to remove those.
