LMTV M1078 1998 3116 - Wiring Issue, I'm flummoxed !!
Kit
Bend Oregon
Hi Gentlemen
First time I've asked for help, I'm humbled. Stripped out this cab for paint and refit. On re-assembly I cannot remember where in the world to plug in the female P31 engine harness plug in the drivers side dash. I've looked everywhere for the male J31 plug. You would expect that it comes over from the PDP in the main dash wiring harness, it does not! WHAT THE HELL AM I MISSING, I FEEL LIKE AM IDIOT. Where should I be looking??
Kit
Bend Oregon
J31 is for the auxiliary panel. You must be winch-less and tach-less.
I am winch-less, tach-less and wit-less! In my 2 older trucks (2-3 years older with early PDP) P & J31 are engine. I cannot locate a wiring diagram for this truck, it is widely claimed to not be released yet.
Thanks for your consideration
Kit
Ronmar
8,092
Port angeles wa
Is she a freak?
Well a 98 should have the black modular power panel, not the green printed circuit type.
On the A0 P31 is indeed the engine connection to the 3116 sensors and controls. On an A1, I am not finding P31… closest I am finding is PX33, which is the shift controller connector…
Kit
Bend Oregon
Hi Ronmar,
Do you have access to the wiring diagram for the 98? I have unsuccessfully searched the entire planet for that, sent a letter to S&S and hassled the military. I think Ill be thrown in jail soon !!
Kit
GeneralDisorder
5,945
Portland, OR
Hi Ronmar,
Kit
I have all the wiring diagrams for every model - and all the other documentation in the TM's, etc. What is your serial number and what are you looking for?
Here's a collection of A0 through A1R schematics I put together. It covers most trucks:
Ronmar
8,092
Port angeles wa
Well it is here in the tech manual section… in the back of tech manuals 20-1.pdf thru 20-5.pdf you will find the wiring diagrams
Kit
Bend Oregon
WOW these are awesome, I will study them to see which one is mine. Cannot thank you enough. This really helps. I'll keep you in the loop as this seems to be a rubics cube issue and nothing if not entertaining.
Kit
Bend Oregon
You said 1998 year model. What do you have.
The ID tag says its a 5/98 A0 w/CAT 3116, however, it has taken a couple days of research but I think this thing is a 98 A0 with a dash, PDP and wiring harness of an A1. I believe this is why I cant make sense of it.
Kit
Bend Oregon
coachgeo
3,480
North of Cincy OH
eventually will get this done right..... which one(s) of these files should you download? I am running Linux Fedora.... and can use searchable PDF's .. but not sure which of these file(s) lets ya do that trick.
GeneralDisorder
5,945
Portland, OR
Click on the "PDF" link under download options. It's not going to be searchable. The images dumped into the PDF haven't been run through OCR and I'm not sure all of them are high enough quality for that to work reliably. They are generally good enough for someone that can read schematics. It's the best option I've come up with a simple download. To get setup with the digital manuals requires GB of data transfer and must be installed under Windows - it uses a local machine web host as it's back end so I doubt it could be easily made to work under Linux.
Kit
Bend Oregon
Thank you General, its exactly what I needed
Kit
Bend Oregon
Your diagrams helped me figure out that the truck I bought had an A1 cab on an A0 chassis, solved!! Thank you very much
Kit
