I started following the lines and got side tracked lolFinally!!!! Good for you. Looks decent. I asked what that canister was before. Where do the rubber lines go to? Would put that start box at the top of your list for replacement. That is an old one that is on its last leg. Keep us posted.
You think they'll come back? They're sitting at 0.6v right nowJust want to make sure you know those hawkers are agm and need a charger rated for agm. Trickle charge over a long time.....
That's the plan. I was just curious if these old guys could be revived. Even if they could, I don't know if I'd ever trust them, especially on long trips. I don't want to get stranded.Use a lithium battery charger to rejuvenate… might work.
Or just go to Walmart and buy 24f batteries and install
What would water in the fuel cell have to do with water in the oil pan? No connection whatsoever.Did you do an engine oil change? With the water in the fuel tank and assuming they tried to start it that way, some could have made it into the engine. You seem to be on top of all the basic stuff. If the engine sounds ok, fingers crossed. Compression engines and water in the cylinders make for a very bad and expensive combo!
Yup, changed the oil before doing anything. It was fairly clean, with a Napa Gold filter on it, so somebody took care of it. Replaced it with fresh 15w40 and a Wix filter.Did you do an engine oil change? With the water in the fuel tank and assuming they tried to start it that way, some could have made it into the engine. You seem to be on top of all the basic stuff. If the engine sounds ok, fingers crossed. Compression engines and water in the cylinders make for a very bad and expensive combo!
I had the exact same issue. See more info here: https://www.steelsoldiers.com/threads/6-5-turbo-dying-on-rapid-decel-psa.213180/So, messing around with the truck some more. Runs like a Swiss watch, but it doesn’t like abrupt applications of throttle, followed by letting off the pedal immediately. It stumbles and dies when returning to idle. Fires right back up instantly though.
So far I've crawled all over it looking for small pinhole leaks in the rubber fuel lines, and found one that was cracked that I missed the first time around. Fixed it but still experiencing the same issue.
Any ideas where to go with it next?
Sounds like the gov. is sticking at no fuel, when you release the pedal the gov. inside the IP goes to no fuel until the RPMs get under 700 or so then it opens the fuel back up enough to maintain idle, you might add some lubricity additive to the fuel and also give it more running time.So, messing around with the truck some more. Runs like a Swiss watch, but it doesn’t like abrupt applications of throttle, followed by letting off the pedal immediately. It stumbles and dies when returning to idle. Fires right back up instantly though.
I'll give this a try. Thank you!I had the exact same issue. See more info here: https://www.steelsoldiers.com/threads/6-5-turbo-dying-on-rapid-decel-psa.213180/
RWH mentioned algae being a likely cause, but I had none. Guessing the inside of my IP was just gunked-up.
Yessir, after it's warmed up. The IP was sticky when I first got the truck. The pedal was pretty stiff, but loosened up after getting it running. Sounds like something internally is still sticking though.Sounds like the gov. is sticking at no fuel, when you release the pedal the gov. inside the IP goes to no fuel until the RPMs get under 700 or so then it opens the fuel back up enough to maintain idle, you might add some lubricity additive to the fuel and also give it more running time.
There is also a mechanical linkage that goes down to the automatic advance piston but I am not sure what influence it may have in that situation.
I am assuming you are talking about after the engine is fully warmed up?
