3116 is a mechanical injection pump with the lift pump on the back of the head. 3126b and C7 have HEUI injection pumps with the lift pump driven off the back of the HEUI pump so the lines are going to be totally different length, etc. Not sure about fitting sizes but there's also a difference in engine displacement, and fuel pressure since the HEUI engines don't operate with high pressure fuel from an injection pump - they use high pressure oil instead.
So I wouldn't assume any of that is correct for an electronic engine. Measure everything before you order part numbers off a random internet spreadsheet.
Much of this sheet is done by
@simp5782, though others help with it now too and it is continually updated based on reports from here in SS. There is no hose lengths on the spread sheet only part numbers for bulk to cut to length.... Fitting and hose are for converting to more modern Push Lock and NOT for direct OEM replacement.
Doing some searching appears OEM is: end of a hose using JIC6 at hose side- and at fitting into engine part's side is NPTF thread. If that is correct then would not the push lock part numbers shown logically work? (and heck of a lot easier for citizen owned FMTV users to work with)?
@Ronmar above points out it appears to him 3116/3126/C7 are same (JIC6) Hopefully one more person; also in a "bit of know" will throw their knowledge in the hat. That will assist in getting the sheet updated.
PS- Looks like the fuel solenoid info got updated already.
