DREDnot
- 476
- 63
- Phoenix, AZ
GET THAT REVERSE POLARITY BULB GUYS!
It fixes this issue.
You need to troubleshoot the brake light switch and see if that is the problem, one thing you can do is simply disconnect it, if the lights go out the switch is bad.Yes, either stop or service, now my brake lights are on unless I press the pedal. Confused. Guess adding the troop seats messed up the lights??
Yes, switch is "bad." Multimeter says it is good but it must not be good under load because it won't trip the relay for the brake lights. Odd. Shows <1 ohm with meter. Shorting the inputs to the switch makes the lights come on. I don't have a milli ohm meter and I'm surprised the circuit is that sensitive.You need to troubleshoot the brake light switch and see if that is the problem, one thing you can do is simply disconnect it, if the lights go out the switch is bad.
Or grossly miss adjusted
I am a little confused, I thought you said the lights were on all the time unless you stepped on the brakes?Yes, switch is "bad." Multimeter says it is good but it must not be good under load because it won't trip the relay for the brake lights. Odd. Shows <1 ohm with meter. Shorting the inputs to the switch makes the lights come on. I don't have a milli ohm meter and I'm surprised the circuit is that sensitive.
Hi,I am a little confused, I thought you said the lights were on all the time unless you stepped on the brakes?
There is no relay the switch drives the lights directly
Yes the switch can ohm out good but not carry a load.
If you cannot find the relay you could put the diode directly across the switch, it certainly would not hurt anything even if there was no relay or if the relay already had a diode.Interesting. It was with the Guard then a PD and I've been undoing their 12 mess. Maybe they put one in. With my tinnitus it will be fun finding it! It was puzzling for sure as I didn't remember one in the schematic and had to check to verify. And yes a diode in parallel with the coil to clamp the spike when the switch opens up is always a requirement. This is very helpful info. Thanks. Will report back.
.So I've run into a similar situation as Mainsail. LED turn signals at all four points, won't flash with incandescent bulb in turn signal stalk, lights up and blinks fine with non-polarity LED bulb installed - but here's the catch, when the headlights are also on, one of the turn signals will not flash -the other 3 points are fine. That same signal flashes just fine when the headlights are off. Even more perplexing is that the culprit turn signals works as it should if the turn signal bulb is removed entirely. Any thoughts on tracking down this LED Gremlin?
I would suggest that you have a ground issue.
Incandescent bulbs are more reliable on an unsteady ground that LED bulbs. Don't go buy a grounding kit. Just need to remember that the HMMWV does not use a "frame ground" for lighting. Every wire has a return path for its ground and every one of those return paths attach to a ground point on the chassis. You need to remove those ground connections, brush them to sparkling clean, then apply anti-oxidant paste, then reconnect those ground paths.
I would add there is no ground dependent on the body (chassis) the only place I know where the ground is attached to the body is behind the inst. panel and that is only to pass the ground via a bolt to the other side of the body panel to a harness on the engine side..
Yeesh, have you tried using the specific bulb that was linked, the one that solved the same problem for me?I've been waiting to post this until I actually do it and take pics but here's the plan. I fooled around with some resistors in parallel with the LED to increase the current draw since the LEDs were't enough to make the flasher operate. Totally going from memory but I think that 800 Ohms was reliable. But don't quote me on that. I used 4, 1 watt resistors (what I had lying around) to make 800 Ohms so each dissipates 1/4 Watt. I plan to splice it into the wiring inside the tail light housings. The dissipation is still way less than a bulb so heat isn't a problem. When I get around to doing it I will post pics and check the resistor value.
This is likely going to be the fix for a thermal type flasher or even a solid state requiring a load. Resistors kits are sold (auto parts stores) to do just that when switching over to LED's. More ThinkingI've been waiting to post this until I actually do it and take pics but here's the plan. I fooled around with some resistors in parallel with the LED to increase the current draw since the LEDs were't enough to make the flasher operate. Totally going from memory but I think that 800 Ohms was reliable. But don't quote me on that. I used 4, 1 watt resistors (what I had lying around) to make 800 Ohms so each dissipates 1/4 Watt. I plan to splice it into the wiring inside the tail light housings. The dissipation is still way less than a bulb so heat isn't a problem. When I get around to doing it I will post pics and check the resistor value.
Great idea for DIY project CamOThis is likely going to be the fix for a thermal type flasher or even a solid state requiring a load. Resistors kits are sold (auto parts stores) to do just that when switching over to LED's. More ThinkingOne might be able to place one resistor at the flasher output lead, taking care of all the flashing load requirements
Experiment and DIY to save a buck.
No blinker fluid required, CAMO
