tacotruck
- 45
- 13
- Pennsylvania
As previously mentioned, I came into cucvsrus' legendary "Mule" thru some bartering with the gentlemen he sold it to.
As it sits, she has about 6700 on the odometer, I got it with around 3000 (roll over if I understand correctly so 103-106k?).
Truck had more or less sat for at least a year prior to me getting into it. Pennsylvania is cruel to cars and rust was starting to set into the body again, so I finally got the excuse to take it off the road to do some body work when a fuel line split. There have been minor repairs here and there (alternator rebuilds, reseal the rear dif, refreshed/returned to stock the front grille area etc) but nothing "big" so far.
The truck is solid shape but could use a lot to make it "perfect". I have to limit the scope however or it won't get finished. Thus scope for this summer is to repair/replace the floors pan from the rear seats back, overhaul the fuel system (lines, probably replace filter, maybe add a secondary filter, potentially replace the tank as I'm not sure if tank is gonna clean up well).
If things go really well there is at least one patch needed behind the driver's seat and rocker work, which would let me get it done enough to potentially drop in a vinyl floor like I've considered but not sure I want to go that far yet as dry rot is really beginning to set in on the tires, and if I want to put any miles on this 100% those will need done and that will be some $$$.
For now, for a start, over about 3-4 hours (but about 4 weeks due to dodging rain...) rear bumper is off, fuel tank is out, going to clean up the metal underneath on the floor with a wire wheel to get an idea of exactly how good or bad various spots are when it comes to cutting and patching. I know for sure the entire tail pan needs to come out, the left rear corner/body mount is just gone. I do already have some panels I plan to use but haven't ruled out just putting an entire complete pan in it.
Stay tuned for next time where we see what's in the tank.
