Primussucks
- 73
- 18
- Dallas'ish, TX, USA
Hi fine folks..
I'm in the process of deleting my air over hydraulic system (going with the single manual hand pump instead), and removing the spare tire carrier. I'm building a camper.
To remove the tire carrier the TM (and all the nuts and bolts tell me) that I need to remove the ether start system. Thats fine.. but my question is...
On my A1R, i have the ether start system, but I don't have a switch in the cab. I'd like to just delete it all anyway, since I will be installing the cat block heater. What all is involved with deleting the ether start stuff, all the way back to the engine? (i can't peak at the engine right now since the cab is lowered and i have no hydraulics).
Thank you.
Thank you.
