Just Purchased my first MEP803A!
Mweiss
New Milford, CT
I did a few tests today:
Placed a voltmeter across the battery meter terminals and started the generator. It read -5mV then ramped down to -3mV.
Then I did the removal of FU1. With it removed, the needle moved less than 1mm into the red, about a needle thickness. With the fuse installed, it moved maybe 2mm into the green. Certainly a lot less movement than I've seen on other videos.
I assume that if the alternator weren't charging, the generator would shut down when the battery is disconnected for lack of energy to the fuel solenoid, am I correct?
rickf
1,430
Pemberton, N.J.
Have you put a voltmeter across the battery terminals while it is running? That is a very simple way to find out if it is charging. You are WAY overthinking this!!!!!
Mweiss
New Milford, CT
A few days earlier I did put a meter across the alternator terminals as instructed, and read 26.5 volts with engine running.
I just want to be sure the unit is 100% working the way intended.
Does anyone know how many millivolts it takes to deflect the meter full scale?
Light in the Dark
5,427
MA
Well when you took the fuse out, the gauge did read into discharge territory... And when put back in, it did move into the green (and then settled back to a neutral state). With the voltage reading, I think its all working right. Remember you got two brand new batteries in that machine.
Best thing you can do is hit the TM Guy mentioned and test accordingly.
Mweiss
New Milford, CT
Thanks for the pertinent page of the manual. As I mentioned, I did that test and it peaked at 5mV and rolled back to about 2 mV after a few moments.
Those must be some super-duper low internal resistance batteries, because I watched one other video last week where the presenter mentioned he just installed new batteries, and the meter on his swung well into the green after startup and then settled to the border between red/green. Mine pretty much sits there like batteries have no sag when the starter engages.
