- 3,728
- 2,644
- Peoria, Illinois
Pretty fine cuttin there!Work in progress.
Roller, brush, or sponge? What type of material did ya cut em out of?Got both tanks painted 2 coats!
IF you cut a background board matching the exterior outline, painted it, and attached it behind the piece itt would give your art an i interesting touch when painted ....not sayin ya should, just another display possibility.For all you truckers out there.
That truck has that style background. The lens on the cell phone alters the view a bit when close up. Same as what I did with the tank.IF you cut a background board matching the exterior outline, painted it, and attached it behind the piece itt would give your art an i interesting touch when painted ....not sayin ya should, just another display possibility.
Is it as brittle as it appears with the grain of the wood and the thinness of material? Or is there a "strengthening" material on back? Liquid glue/binder?3D Dino Art
IMPRESSIVE technique! =)No additional support. Just 1/2" pine board and some technique.
