264Charlie's M51A2
264charlie
32
Gainesville, TX
Today's projects
Fixed the fuel shutoff; the plunger was bent so it would not slide within the nut, and the handle in the cab was missing.
I installed a set of oil filter adaptors to accept spin-on-style filters. This seems like a significant improvement.
Identified the fuel leak in the line running from the side of the injection pump to the rear of the fuel filter
I discovered a missing air filter. Hopefully, the cylinder walls are not trashed from grit.
264charlie
32
Gainesville, TX
After looking at the TM, I should have a nylon line with a compression fitting. I ordered some fuel-rated lines and new OE-style fittings.
I should be able to get the fuel filter replaced and the oil changed tomorrow. Then, back to waiting on parts. The truck builds air pressure but does not hold it, so I might try and track down some air leaks if time permits.
264charlie
32
Gainesville, TX
Does anyone with a multifuel 5-ton have a picture of how the original air cleaner should work?
Looking at the TM, the filter should not be open on both ends (assuming). I ordered the part number in the TM, and the filter I received is open on both ends and is short. Maybe I'm missing a part; if so, I don't see it on the diagram.
264charlie
32
Gainesville, TX
I removed and cleaned the turbo. It started right up and I was able to move it. Next, I'll pressure wash it and make a plan to tackle the brakes and axles to see what kind of shape they are in.
Pick up an Ebay accessory :)
264charlie
32
Gainesville, TX
View attachment 928546View attachment 928547
Looks like I need this part. Does anyone have one for sale :)
