MTVR ECM Configure File
MAdams
126
San Dimas, CA
Here is the parameter configuration file from my 2002 MK23. This is useful if you need to replace your dead ECU with a new one. Click this link https://www.dropbox.com/s/fd0h7fmvj418ag5/9SM03523_ECMREP_2020-02-18_18.37.38 MTVR Stock.xml?dl=0
Also attached is the 355/410 hp flash "tune" that I think is what is is loaded into our EMC's. The file name for this is 2368687.fls which you can google as "CAT 236-8687". I have not confirmed that this is the correct flash file, but its all I have found so far. I also have the 505hp file if you're feeling brave :) **update** SS won't allow me to upload the flash file. If you want it, PM me your email address**
Lastly, I am new to all of this and not an expert. Adept Ape explains it in better detail here.
MAdams
126
San Dimas, CA
I found the correct flash file for our engines and the link is below.
Recap on how these work. The flash file is the HP/Torque tune and that cat PN# is 220-4352-00(see the attached picture). The configuration file are all the parameters of these trucks ie the coolant temp wiring style, tachometer signal, how the jake brake is wired etc. You will need both if you're replacing your ecu.
Flash file - https://www.dropbox.com/s/8a7pr85c7815fa1/2204352.FLS?dl=0
Configuration file - https://www.dropbox.com/s/fd0h7fmvj418ag5/9SM03523_ECMREP_2020-02-18_18.37.38 MTVR Stock.xml?dl=0
Download these now and save them in case you need them in the future.
IridiumRed
39
NW MO, north of KC
What version of Cat ET is needed to work w our trucks (MTVRs)?? To scan/test/reflash? Would 2019c work??
Im having trouble w my 03 Mk25, i think the engine ECM lost its memory (went to start it the other day, it just cranked and cranked, it had sat for 2 weeks or so, hadnt done anything to it since last time run ning it. TIM says the engine ecm is not found / not installed)
Want to get cat ET so i can scan / test / reflash truck (would like to be able to do other trucks down the road, why im going thru the hassle of getting software / hardware vs just having someone else fix ecm for me... besides i just like go do all my own work), just not sure on what version to get (had been planning on 2019c, but just read that military trucks might need something different?? Sidenote, i may have a line on 2020a for military vehicles...)
I plan on reflashing mine to at least the 505hp version, tho the 530 rwhp version sounds -real- interesting.
As a sidenote, im going to get test harness so i can hook directly to my ECM, bypass truck harness, so i can identify if its the ecm or truck wiring that has issue. (In addition to comm3 adapter of course, and adapters so i can also read from truck harness too)
DeMilitarized
946
Gainesville, GA
2019a works fine no problems for me.
DeMilitarized
946
Gainesville, GA
ANOTHER REMINDER!!!! ALWAYS COPY YOUR CONFIGURATION FROM YOUR TRUCK AND SAVE IT IN A SAFE PLACE AND EVEN MANUALLY WRITE DOWN YOUR INJECTOR TRIM CODES!!!!!! I totally forgot and flashed the 505 which 90% of the time resets your configuration and you will have to pull the valve cover at a minimum to get the injector trim codes if you forget this step.
