- 4,372
- 3,812
- Near Austin, Texas
Most of the intercom cables run along under the roof line and are rather loosely draped. They are held up by loops that bolt to threaded posts welded to the hull.
The single cable going forward runs along the right side, from the main intercom control box (AM-1780) above the radios to the right front "shotgun" control box.
On some V100s, this cable runs under the roof line, however many (including mine) route the cable down under the side seat and up the corner of the forward wheel well/hull line to the control box.
Another cable runs from the passenger box across the front of the roof beam to the driver's side box.
A cable runs back under the roof from the AM-1780 to the rear position. That intercom box can either be on the rear hull wall (as in mine) or on the back of the wheel well. The coaxial cable from the right rear antenna also runs along with this intercom cable.
The power cable for the radio system comes out of the top of the engine bay wall and goes across the roof and straight down the wall to brackets welded to the hull wall, behind the radios.
There is a square speaker mounted to the hull wall to the left of the AM-1780, another on the hull wall by the driver and passenger.
Captions on pictures explain what they are. A couple were taken in a different V100.
Cheers
Cheers
