Keith Knight
- 2,164
- Wauchula, FL
Mine is definitely a one piece filter housing.
There's two of one gasket - block to spacer, spacer to cooler. And one of the divided gaskets - cooler to filter head/plate.It looks like the spacer is still attached to the cooler? Isn't there a gasket between the cooler and spacer?
You want an MLS (Multi-Layer Shim) style WITH a fire ring to prevent the exhaust gasses from working their way between the layers. If you want a really high quality (better than CAT) alternative, this is one option:They look like the are sold in many thickness variations from single sheet metal to multi layers to cat design.
We just pulled our HUEI pump today. What a tetris game to get it out of that space. I finally pulled the cover from the fuel pump where the fuel lines attach and took her out in pieces.Port:
Thanks! It was a labor of love and very expensive, but I no longer feel like I'm driving a ticking timebomb.That’s a good looking engine! Nicely done!
