- 7,480
- 10,504
- Papalote, TX
So I was incorrect, the ones I listed are for serial number 246XXX and below..
As usual, I believe you are correct. The TM 9-2320-387-24P C05 reads on page 0135 00-1 as Item 9. but with knowing the serial number of the truck, we have to pick the next item below that. Hey P, you may benefit if you had the TM for this truck. I found a free copy here:
THANKS for the updated parts TM!!! the one I had did not list the 1152A1
So [B]Pstyckiewicz[/B] your UOC for the M1152A1 is UUA, when you look up a part and it has the UOC codes listed under the part description that is the code to look for, if the part does not have any UOC codes listed under the parts description then it fits ever vehicle covered by that parts TM.
And I was incorrect as the late model serial number 246xxx and above use a different tie rod end than all the other HMMWVs
Never too old to learn..
